Water Penetration On Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 10:04 PM   #1
Water penetration on slab
I am half way through building a garage, the frame is up the outside brick wall and roof tiles are on. I have a one brick step down. I had to have a termite barrier installed and the official supplier said it has to go from the top of the slab and lay on top of the first brick course, which I did. The bricklayer laid his flashing on top of the termite barrier and attached it to the frame. So far so good. Now with all the rain of the last couple of days I have water penetrating from somewhere and coming from under the wall frame where it sits on the concrete slab. Because I have not yet had the walls lined I still have access to the wall and frame. I cannot see anywhere where the water might be coming in. The only thought I have is that it is somehow coming in across the termite barrier.
Has anyone else had the same problem?
dujon is offline   Reply With Quote
Old 07-23-2011, 08:12 AM   #2
Rewards Points: 5,336
How high is the ground level around this area and is it graded away from the structure?
Ron
B. Franklin 1759
Old 07-23-2011, 01:18 PM   #3
Rewards Points: 150
Probabilities are high that the brick lug, the step down area, is full of mortar. Did your mason leave every 3rd brick out and clean the lug after he was finished? If the lug is full of mortar it will not drain. I assume you checked the weep holes.
TrapperL is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 03:47 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
