Water Patch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2011, 05:48 AM   #1
Water patch
Hi everyone! I am a longstanding DIYer, and first post! Whoohoo!
The question relates to water ingress in the basement. On one wall there is a small patch of what I assume is residue/chalky yellowish white material. The patch is a circle with a diameter of about 4ft. I haven't seen actual water for a while and we seriously had one of the rainiest March's in a while with approx 4-5in of rain.
Inspecting the ground outside there is a definite slope toward the house on the side with the leak. There is also a concrete patio that appears to have settled toward the house as well and creates a perfect "V" for water collection and can easily explain the existence of this patch. There is a sump pump in place, and that is the only spot along the entire basement.
Since the patch exists, I would love to get it taken care of and never have an issue with it again. I assume part of the issue is grade/drainage away from the house, so I would obviously fix that with mudjacking or replace the patio and grade. I could also just pull out the patio and redo the barrier on the foundation wall if needed. The alternative, i suppose is lock the interior wall with painting.
Any advice to add? I will grab a picture for later. Thanks!
cscpianoman is offline   Reply With Quote
Old 03-30-2011, 07:08 AM   #2
Rewards Points: 4,806
welcome aboard have a question - how do you propose to ' lock the interior wall with painting ' since there's nothing avail that would accomplish this work at a reasonable cost OR lack of experience ? ? ?
Old 03-30-2011, 08:26 AM   #3
Painting
Good point,
I was primarily thinking a basement sealer, but I have mixed feelings about those.
Trying to find any conclusive info for waterproofing a basement is very difficult to find on the interwebs.
My thought was to
1) retar/rewaterproof exterior basement along the one face
2) regrade with patio mudjacking and fill dirt
3) interior waterproof with some sort of sealant.
Old 03-30-2011, 09:32 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,736
Originally Posted by cscpianoman View Post
Good point,
My thought was to
Ayuh,... Options 1, or 2 are fine...
Option 3 just slows the water, leaving it Inside the wall, deteriorating it further...
Old 03-30-2011, 10:50 AM   #5
perfect!
Yeah, I figured number three wasn't really a solution. I won't waste my time. Looks like I get to break out the sledge
Thanks for the input. Part of me wanted to rip out the patio anyway to replace it with a nice deck.
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 07:45 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Well Water snuggles2010 Plumbing 3 04-13-2010 01:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
