Water Logged Porch Columns. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2016, 12:29 PM   #1
Rewards Points: 72
Water logged porch columns.
Hello guys, I have a question.
My home is still under warranty. Do I need to have them come out and re-do these porch columns? I took off some siding at the bottom to find water logged beams.
I'm certain the posts are secured to galvanized post bases, but they are under the slab, attached to the footings. They obviously just poured the slab higher up and let the concrete flow right up against the beam.
I'm concerned water will continue to attack these beams.
Anyway to seal this area against water?
sulkair is offline   Reply With Quote
Old 04-04-2016, 12:34 PM   #2
jlhaslip's Avatar
Rewards Points: 1,470
Re: Water logged porch columns.
Because I can see those gouges in the Posts, they are what I call direct burial Pressure Treated.Being wet should not be a problem for the next 40 years or so.
On the other hand, you might live there for 50 years, so call them up and request a Warranty Claim. See what they say.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 04-04-2016, 12:43 PM   #3
Rewards Points: 72
jlhaslip, Thanks. What I'm hearing from you is that it will be fine, but it was done incorrectly?
Old 04-04-2016, 01:14 PM   #4
jlhaslip's Avatar
Not the way I would've done it.
I am guessing they had the posts set in place in order to attach the roof and the posts got poured into the slab.
Pouring the slab and then mounting a bracket (either in the wet concrete or drilled in after it sets) would be the more correct method in my mind.
I would have braced the roof against the building, poured the slab, then set the posts per above.
Old 04-04-2016, 02:07 PM   #5
Rewards Points: 72
Understood. Once these things get nice and dry I think I'll get some powerful oil based paint and put a few thick coats on the concrete and first 4 or 5 inches of the treated post all to be hidden by some siding around the bottom. I'll leave 1/4 inch between the siding and slab to allow air to get in there. And call it a day. Thank you!
The Following User Says Thank You to sulkair For This Useful Post:
jlhaslip (04-04-2016)
Old 04-04-2016, 03:39 PM   #6
Rewards Points: 13,446
If those are real wood post wraps they never should have been in direct contact with the slab.
There just going to wick up water laying on the slab and rot out.
Old 04-04-2016, 03:51 PM   #7
jlhaslip's Avatar
If you look closely at the picture, the posts are PT.
Old 04-04-2016, 03:54 PM   #8
Rewards Points: 72
Yep! OSB siding material. And that's exactly what happened, hence why I pulled the bottom of the wraps off, and found the post not set-up in an anchor but buried in the slab.
When I rebuild the bottom of the wraps, I'm going to use some type of composite decking material, and float them 1/4 to 1/2 inch above the slab.
Good idea???
Old 04-04-2016, 03:54 PM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... That's also what I'm seein',....
In 50 years or so, you can fill the holes left by the rotten posts, 'n do it Right at that time,....
The Following User Says Thank You to Bondo For This Useful Post:
Old 04-04-2016, 05:30 PM   #10
Rewards Points: 72
Haha! Ok, sounds good. I'm 45, so I'll be letting someone else worry about it Thanks Bondo!
Crumbling foundation under front porch and water leakage mbrando1994 Concrete, Stone & Masonry 9 02-01-2016 07:50 AM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 06:51 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
