Water Leaking Through Basement Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 05:49 PM   #16
kwikfishron's Avatar
Rewards Points: 782
It is a well water pump switch. The neighbor has one and I wish I did.
It says 220 on the label, I know you can see that.
kwikfishron is online now   Reply With Quote
Old 10-22-2010, 06:29 PM   #17
Registered User
Rewards Points: 526
230...... 1/3 HP. lol. Nice 180* turn-around, irc....
Gary
Old 10-25-2010, 08:18 PM   #18
Rewards Points: 16
Okay everyone, thanks for the responses. Now that you point out the well, I feel a bit foolish...
Anyway, I guess I'll be digging this up in the spring. And I'll be careful not to dig through the wires.
Oh, also no idea what "NEC" means.
dismas is offline   Reply With Quote
Old 10-25-2010, 08:21 PM   #19
Rewards Points: 640
NEC is the National Electric Code... basically all the minimum rules and guidelines you must follow when doing electrical work
BlueBSH is offline   Reply With Quote
Old 10-26-2010, 05:06 AM   #20
Rewards Points: 4,734
BEFORE YOU DIG, TURN OFF THE BREAKER CONTROLLING THE SUBMERSIBLE PUMP - you've got lots to learn about owning a house so no sense electrocuting yourself before you learn more don't be afraid to ask questions, either,,, most of us got learned from others - VERY few of us learn anything by ourselves
Water leaking into basement through deck john8791 Building & Construction 20 11-01-2015 10:24 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
Drain tile questions for retaining wall installation. Tmaxx1 Landscaping & Lawn Care 11 06-10-2011 11:17 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
