Water Leak From Tub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 12:45 PM   #1
Question
water leak from Tub
I'm remodeling my bathroom. water had gotten in the drywall and wall and flooring. I found Black Mold. Took all out. The studs and base plate are soaked but not deep. studs and base still have integrity. My question is, Do I have to remove the wet wood or can I take it all strip it down to frame and let it dry out. And there's no way to take the siding off that is on the back side of the studs. also the rim joist. there isnt any way to get between that and the siding cause I'm pretty sure there might be some water on the outside of the rim joist.
rldoerffel is offline   Reply With Quote
Old 01-19-2012, 12:50 PM   #2
Rewards Points: 13,458
No way to see it from here, how about a picture?
It's all going to have to dry out, fans, demumidifyer.
Once dry recheck the wood, treat it with Boric Acid. If you go in the painting area at Lowes or HD they sell products that get sprayed onto the wood to control mold.
Old 01-19-2012, 03:20 PM   #3
Thank you. Will start there.
Tags
bathroom , mold , studs , tub , water
Fixed water leak now low pressure whitecrow Plumbing 15 08-13-2011 11:36 AM
Copper Pipe Leak Caused by Hard Water? Asathd Plumbing 20 07-09-2011 09:06 PM
No water in house dls6w4 Plumbing 10 02-12-2011 06:45 AM
Water softener leak - how do I set it to bypass? Cylanth Plumbing 4 07-21-2010 09:24 PM
Water Leak swoop Plumbing 2 01-14-2010 06:02 PM
