Water Leak Into Basement Just Below Front Porch Front Door Entry. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-27-2010, 09:08 AM   #1
water leak into basement just below front porch front door entry.
There is one step up to the landing to the door entry. This is not a large porch - just in front of the door. Will I need to remove the porch to seal the area that the water leaked into the basement? This is the only area of the leak.
roncarolron is offline   Reply With Quote
Old 10-27-2010, 09:19 AM   #2
Rewards Points: 216
A few pictures of the area, and the probable source of the water would be very helpful.
orange is offline   Reply With Quote
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 08:20 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 07:38 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 11:59 AM
