Water Heater Closet - Drywall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-06-2012, 12:24 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,110
I'm building a closet for my water heater (new location outside).
My understanding is that it has to have 5/8's drywall on the sides next to the house.
Ok...not an issue....but do I also have to cover the 2x4 studs that make up part of the frame?
ddawg16 is online now   Reply With Quote
Old 07-06-2012, 02:00 PM   #2
Rewards Points: 282
probably a local code issue....if gas fired, then you almost certainly have to fire rate ALL exposed wood (ie drywall it).
jcrack_corn is offline   Reply With Quote
Old 07-06-2012, 02:49 PM   #3
JOATMON
ddawg16's Avatar
That is sort of what I suspected.
I have access to sheet metal and a nice long break. Is metal over wood considered fire proof?
Old 07-07-2012, 12:22 AM   #4
GBrackins's Avatar
Rewards Points: 2,108
drop a dime to the local inspector, after all he is the one that must bless your work. what an inspector in one area allows is not the same in another location.
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-07-2012, 12:30 AM   #5
Rewards Points: 13,244
Drywall would be a whole lot easyer to work with and cheaper per square foot.
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
