Water Getting Behind T1-11 Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 01:03 PM   #1
Water getting behind T1-11 Siding
Had an addition put on this summer. Had a horrible storm with driving horizontal rain last week. Water got behind the T1-11 siding damaging drywall, etc.. I have the contractor coming back this week.
My question is how will he be able to correct this situation? Ideas? I assume the water was getting in between the seems of the T1-11.
ivanl3 is offline   Reply With Quote
Old 12-05-2010, 01:24 PM   #2
KCB
Is it at the top of the wall?around a door/window????
Whenever i put up T1-11 i use a wheather resistant sealer on the seams T&G or liquid nail etc...
Proper flashing around doors,windows and the roof line of course.
Sorry to hear of your problem
KCB is offline   Reply With Quote
Old 12-05-2010, 01:28 PM   #3
kwikfishron's Avatar
Rewards Points: 998
No need for the dbl post for the same problem.
Still would like to see the outside pic though.
kwikfishron is online now   Reply With Quote
Old 12-05-2010, 02:07 PM   #4
Mystery solved. The leak was not through the T1-11. There is an exhaust pipe on the roof above the commode room. This where the leak was occurring and is easily corrected. I am surprised that it took this long for the
problem to manifest itself though. I hope there is no rotting in the walls/roof from previous leaks that are unseen.
This makes a lot more sense. For that rain to have gotten though the T1-11, the Tyvek, the insulation and the drywall seemed impossible.
Thanks.
Old 12-05-2010, 04:35 PM   #5
KCB
what kind of insulation do you have? Fiberglass will dry out but R factor could be damaged.If it were me i would remove drywall/insulation, dry out the area and replace.Similate a rain storm(water hose) and make sure leak is fixed while yr there.
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 09:16 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
