Water On Garage Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 08:30 PM   #1
Water on garage floor
Every winter my garage floor has a pool of water from snow that melts off my car. This tends to seep into the attached basement wall and has caused damage to the insulation and drywall. For a temporary fix, I installed self-stick vinyl wall base and then caulked where it meets the garage floor. I think that has improved things, but I think I should address the puddles in the garage also. What should I do?
kraklowm is offline   Reply With Quote
Old 06-13-2010, 04:59 PM   #2
Registered User
Rewards Points: 5,210
The garage floor is required by code to slope towards the car door in case gasoline leaks from the vehicle. Either pour a new concrete slab or possibly cut sloping grooves in the existing slab for drainage. Ask your local building Inspector on this....
Be safe, Gary
Gary in WA is online now   Reply With Quote
Old 06-14-2010, 04:41 PM   #3
Rewards Points: 640
Be safe, Gary
really? huh wish they would of done that around here... our code wants it like a basin sloping inward towards a center drain..... seems better to slope towards the door though
BlueBSH is offline   Reply With Quote
Water in Garage walds11 General DIY Discussions 7 02-14-2010 04:15 PM
Making a floor in a garage. What size floor joists? GD73 Building & Construction 2 07-19-2009 07:07 PM
Basement water meter below floor level redfox1 Plumbing 5 12-10-2008 09:20 PM
Raising Garage Floor to match House Floor felice_oggi Building & Construction 2 09-22-2006 08:26 PM
cracks in the convrete garage floor - water seeping in robphelan Building & Construction 2 01-06-2006 05:19 PM
