Water Flowing Under Patio. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2009, 09:23 AM   #1
Water flowing under patio.
Rain water is flowing under a stone patio and causing a build up of water to seep into the basement. We have added drain tiles and patched the wall. The question is how to stop the water from going under the patio without replacing the patio? What can we fill the opening with? The edge of the patio that meets the grass is the area we have to deal with. Any suggestions?
Building is offline   Reply With Quote
Old 05-09-2009, 09:26 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 662
Ayuh,... Change the grade,+ divert the water....
Bondo is online now   Reply With Quote
Old 05-10-2009, 01:25 AM   #3
Ways to change the grade so dirt doesn't wash under the patio?
______________ l____________wall here___________________________l
/ / building here>>>Wall of building is here. >>>>>>
__________/
Sidewalk>>
_________/_____/_Patio>>>>____________________________________/ ^wall here
Grass all along here>>and water seeps under the sidewalk. If we raised the grade by adding dirt where the grass is, wouldn't the dirt all eventually get washed under the concrete? Is there another way to change the grade other than adding a foundation wall?
Last edited by Building; 05-10-2009 at 01:35 AM. Reason: My drawing is altered when I save it.
Old 05-10-2009, 02:00 AM   #4
I think I found a partial answer. I'll post it in case it can be helpful to someone else also. Still open to other ideas.
I googled the following: Topography and Drainage • Land is seldom flat • Often change the
Old 05-10-2009, 08:18 AM   #5
probably installing a catch drain's the best solution ( 4" perf pipe in stone-lin'd trench ) directing wtr somewhere else.
you'll never stop wtr from entering the bsmt once the house's blt incorrectly UNLESS you invest lotsa $$$ which probably won't be returned when the house's sold.
yesitsconcrete is offline   Reply With Quote
Tags
patio , water damage
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
