Water Filling Up Window Well - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 11:01 PM   #16
Rewards Points: 558
this should help:
epson is offline   Reply With Quote
Old 08-20-2012, 01:29 PM   #17
Sounds like it's time for a professional
Hi PB,
You definitely need to have a professional waterproofing company look at this issue. With what you have described you will need a better window well drain in order to keep draining properly.
Last edited by beenthere; 08-20-2012 at 03:40 PM. Reason: removed offer of services
Ameri-Dry Guy is offline   Reply With Quote
Old 08-20-2012, 04:08 PM   #18
Rewards Points: 1,580
Originally Posted by epson View Post
this should help:
Nice drawing!
My window wells never had a drain so when they did fill up they leaked through the window into the basement (down wall into drain channel around perimeter of basement floor into a sump pump. Pump pumped it out of the house about 12" and the system recycled itself!
I extended the sump discharge 20' away; still had some water in well. Builder wanted to drill a hole in foundation to drain the window well into the house and into sump pump. Not my idea of keeping water out!
I finally installed a drain in well that goes out downhill about 15'.
This only works if you've room to pitch your drains away from the house. Otherwise you'll have to do as suggested and connect to your foundation perimeter system if you have one. If not, water flows downhill; install whatever you need to get it downhill.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
cjm94 (08-20-2012)
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
No hot water in kitchen and dishwasher is not filling water lol Plumbing 3 09-07-2010 11:47 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
