Water Dripping From Upper Deck Onto Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 11:28 AM   #1
Water Dripping from Upper Deck onto Patio
I am looking for some design ideas. We have a fine second story deck planked with Brazilian Tigerwood. Under a section of this deck is a ground level patio with our Hot Tub / Spa. The problem that I am trying to solve is water dripping from the upper deck (rain/snow/ice) onto the Hot Tub. Any under-deck water deflecting solution would tend to build up with ice during the winter, unless I add roof heating cable. We also like the appearance of the stained beams and deck planking when viewed from the Hot Tub. We don't want a roof over the upper deck, nor do we particularly want to floor-over that section of the upper deck. Any ideas would be welcome!
JamuJoe is offline   Reply With Quote
Old 11-21-2010, 01:14 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,714
Ayuh,... Sounds like ya want yer Cake, 'n eat it too....
Either the water has to be diverted, or gravity takes over,... Period....
Move the hot tub maybe....
Old 11-21-2010, 04:41 PM   #3
joed's Avatar
Rewards Points: 13,712
The only solution you didn't discard is caulking all the cracks in the deck. And that is very poor solution that might not even work.
You need a roof of some sort.
Old 11-21-2010, 06:23 PM   #4
Household Handyman
Rewards Points: 1,408
You didn't mention location, just that you do have a rain/snow/ice situation at times. I visit the Atlanta, Ga. area often as my sister/B-I-L live in the area. They are realtor's so I have visited many homes in the northern Atlanta area for sale which do have the second story decks and lower floor decks. One thing I have noticed up there is some type of product which goes underneath the decking to catch any rain/water, is slightly sloped to provide run-off, and guttering to divert this run-off away from the lower patio. The bottom of this product comes in different colors and patterns. I have seen many hot tubs on the patios underneath these second story decks. They do get some, occasional freezing up there during the winter months. Maybe do a "Google" search for this product line.
Old 11-22-2010, 09:20 AM   #5
SteelToes's Avatar
Rewards Points: 150
Hey , what about putting some tempered glass panels , I've seen those in Mexico
SteelToes is offline   Reply With Quote
Old 11-22-2010, 10:33 AM   #6
Rewards Points: 5,336
They sell clear wavy panels at home improvement store that can be installed so as to shed water while maintaing a view of the underside of the deck. You just need to improvise a support mechanism.
Ron
Old 11-22-2010, 10:51 AM   #7
SteelToes's Avatar
Rewards Points: 150
Ron
Thatís a good idea Ron, and itís probably cheaper than tempered glass panels. As far as the support mechanism goes I think that easiest way would be to rip some matching boards..so there is a slope ..attach them to the existing joist in the same direction ...stain match and attach panels over it.
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 11:31 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
