Water Damage To Exterior Wall With Rot And Mold - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-12-2009, 02:40 PM   #1
Exclamation
water damage to exterior wall with rot and mold
We had a leaky roof in the back room of our house for a while, we finally got the roof fixed and were replacing some dry wall that had become moldy, but upon removing the dry wall we found rotten, moldy wood underneath. How should we go about replacing the rotten portion of the exterior wall?
(SEE PIC)
Any help would be greatly appreciated.
-Brendan
bjoldham is offline   Reply With Quote
Old 08-12-2009, 03:27 PM   #2
Rewards Points: 582
Hard to be sure from a photo, but it could be the mycelium of dry rot.
stuart45 is offline   Reply With Quote
Old 08-12-2009, 04:10 PM   #3
I believe you're right. I've been wondering what to do, about not only replacing the wood, but also how to keep it from spreading to the other wood. I've read about different mildicide products but it seems quite overwhelming at this point.
Old 08-12-2009, 04:47 PM   #4
Rewards Points: 582
The problem with dry rot is that unlike wet rot it can travel across plaster and brickwork to find more timber for lunch. The first step is to remove the leak which you have already done. The next step is to find out the extent of the damage and dry the area out. You then need to remove all the affected timber and also at least 1 metre of good timber back from the rotten. All rotten timber needs bagging up and burning to kill the spores. New timbers need treating. As dry rot can live in plaster or brickwork (it can't get any food from these however) you might have to have this treated. There are specialist companies that deal with timber rots, but when they see dry rot the signs come up in front of their eyes, or in your case $ signs. The Building Research Establishment has done a lot of reseach into dry rot lately, and the latest info is that if you remove all the conditions that the fungus needs to survive it will usually die after about 1 year. I could e-mail you the BRE booklet on dry rot, its recognition and control if you like.
Old 08-12-2009, 05:22 PM   #5
That would be cool.
Old 08-12-2009, 05:24 PM   #6
Rewards Points: 582
I need your e-mail address.
Old 08-12-2009, 05:26 PM   #7
sorry, bj_oldham@yahoo.com
Old 08-12-2009, 05:33 PM   #8
Rewards Points: 582
Have sent it. Hope you get OK. My computer skills need a bit more work.
Old 08-12-2009, 05:36 PM   #9
Rewards Points: 582
Have just had a failure notice. Will try again.
Old 08-12-2009, 05:41 PM   #10
Rewards Points: 582
If you don't get it try e-mailing me clarksurveys1@btinternet.com
Old 08-12-2009, 05:48 PM   #11
Thanks a whole lot my family and I really appreciate it.
Tags
exterior wall , moldy wood , repair , rot , water damage
