Is This Water Damage? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 02:15 PM   #16
Rewards Points: 13,732
The wind howling outside sounds like one of those money counting machines to me.
So far all we have is some tress down across some roads and a power line down.
Old 10-30-2012, 02:26 PM   #17
Re: Is this water damage
Alright Joe, Storm seems to have moved along.
Let me know if these pictures help. What's the best way to remove some of this siding?
http://i1101.photobucket.com/albums/...0/DSC00659.jpg
http://i1101.photobucket.com/albums/...0/DSC00658.jpg
mattmili is offline   Reply With Quote
Old 10-30-2012, 03:34 PM   #18
Rewards Points: 35
You have to start a row above where you want to look since you are needing at the bottom. That way you can take the fasteners off the siding piece below. Pretty easy stuff, just take your time and don't cuss too much at the siding.
http://homerepair.about.com/od/exter...ng_ziptool.htm
SeanB is offline   Reply With Quote
Old 10-30-2012, 05:58 PM   #19
Thanks for the information and link Sean! Greatly appreciated.
I'm sure I'll be cursing quite a bit.
Tags
foam insulation , siding , weather proof
Cement cracks in foundation after water damage Ginette Building & Construction 4 09-06-2010 06:14 PM
Water damage. How bad can it be? alexin General DIY Discussions 3 08-23-2010 01:53 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
