Water In Crawl Space - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-02-2010, 07:12 AM   #1
Water in Crawl Space
I have two similar quotes for taking care of water in my crawl space. Bothe quote what I call "French Drains". One quotes with a 3/4 hp sump pump, the other with a positive gravity drain to daylight. Both quotes are under $3,000 and include poly plastic vapor barrier covering 99.9% of ground.
House is 30 years old, never a problem until this year, water/mud in highest point, some standing water in lower corner. Lots of rain here in central North Carolina. Pooling has now occured twice, both times after very heave rain. Cape Cod style home with no gutters on front of house.
Which will be best - positive gravity or sump pump?
turnergil is offline   Reply With Quote
Old 04-02-2010, 08:16 AM   #2
Gravity drain will work if you loose power, sump will not unless you have a Gen
A Daylight drain if severe flooding may possibly let water in ?
How is the crawl space walled in from the outside weather ?
Old 04-02-2010, 08:26 AM   #3
Scuba Dave,
It is masonry construction (cement block / brick) with standard vents & door.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 12:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 03:11 PM
Inadequate center support in tight crawl space 4just1don Building & Construction 5 09-28-2008 03:29 PM
crawl space confusion shoestring General DIY Discussions 1 07-27-2008 01:06 PM
