Water Coming Up From Corner Of Basement Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-29-2011, 09:35 AM   #1
Water coming up from corner of basement floor
We experienced the fury of hurricane Irene this weekend and found water coming up from the basement floor in a couple spots in the same section of the basement floor. It was pouring in like a garden hose turned on low to medium at times. I realized that rain water from the front yard is where its coming from because whenever rain water was puddling in the front it was also coming into the basement. For starters, I plan to further extend the gutter downspouts to the street beyond the 10' away they already go to. How do I fix water coming up from the basement floor? This only happens wheb we have a heavy rainfall. Suggestions would be greatly appreciated.
psubaron is offline   Reply With Quote
Old 08-29-2011, 10:14 AM   #2
Rewards Points: 2,238
Post some pictures of the outside of the house; showing the problem area.
rossfingal
rossfingal is offline   Reply With Quote
Old 08-29-2011, 10:29 AM   #3
I will be home in about two hours and will post some photos as soon as I get there. Thanks for the reply.
Old 08-30-2011, 08:50 AM   #4
Here's the one picture I snapped before my phone battery went dead. Sorry for the delay...had to help my cousin get their basement dry yesterday.
Water coming up through cracks in basement rockarmygreen Flooring 11 04-09-2015 09:26 AM
water coming through basement concrete floor jboland Building & Construction 7 04-29-2011 06:50 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Bathroom floor wet; water coming _out_ of bath overflow. oceanclub Plumbing 6 01-09-2008 09:47 PM
