water comes down basement walkout stairs
The area surrounding the entryway needs to be raised in some way or atleast some type of small irrigation system needs to be installed to be included with the trench you dug out. The only thing I could suggest at the moment, would be to dig a small trench, leading STRAIGHT away from the entryway. Make it about 6-8 inches deep, fill the bottom 2 inches with gravel, insert a PVC pipe with holes drilled down the length. (usually just the sides or tops, so the water flows down the pipe before running out into the soil). Then cover the rest with gravel, and cover back with the sod//dirt. This is the quickest and simplest solution (but not always the easiest at making look pretty when finished)
