Water In Basement Caused By Hyper Barric Pressure - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 11:37 AM   #1
Water in Basement Caused by Hyper Barric Pressure
I live in Central New Jersey and between the months of June thru September I experience a slow leaking of water along one wall of my basement. I believe Hyper Barric Pressure is the cause of this in the hot summer humid months. Does anyone experience this and what can be done to resolve this issue. thanks, joe
josephkahl is offline   Reply With Quote
Old 08-10-2012, 11:56 AM   #2
concretemasonry's Avatar
Rewards Points: 2,578
Humidity would have nothing to do with causing a leak.
How much rain have you had in that period? It could be due to the amount of rain or the draingage not being right. Excess water in the soil would cause hydrostatic pressure that can force water through cracks or cause the wall to fail.
Do you have any drain tile (exterior or interior)? If you do not or if they have plugged or failed, the result is more water in the soil and greater hydrostatic pressure.
Since it is only one wall, it probably is not due to a rise in the water table.
Dick
concretemasonry is online now   Reply With Quote
Old 08-10-2012, 10:12 PM   #3
Rewards Points: 149
Have you checked your gutters and grading?
LVDIY is offline   Reply With Quote
Check valve gimaarob Plumbing 13 10-27-2011 11:13 PM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 02:28 PM
no hot water pressure in sink, but plenty in tub Turtle learner Plumbing 5 10-20-2010 08:45 PM
Water pressure dropping tucsoncop Plumbing 2 04-25-2009 01:19 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
