Water In Basement After A Thaw - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2013, 02:05 PM   #1
water in basement after a thaw
Hi,
I am a newbie to forums. Pls. pardon any oversights.
I have noticed a small amount of water (puddle) at the junction of the wall with the floor in my basement especially after a thaw following a significant snowfall. It dries up in the following couple of days and it is about 15 feet from my sump pump which works very well.
It is a new house built 6 years ago and this has happened a couple of times this year for the first time (at least I have noticed it for the first time).
I asked the builder who has said it is a minor hydraulic pressure problem and should not have long term consequences. Should I be worried or forget about this?
Please help!
longnailed is offline   Reply With Quote
Old 03-22-2013, 04:17 PM   #2
Rewards Points: 12,830
No foundation sealing on the outside.
No drain tile on the outside of the wall.
No drain tiles under the slab leading to the sump pump.
Grade not running away from the foundation.
Mulch or flower bed up againt the foundation.
No gutters or the down spouts do not run far enough from the foundation.
longnailed (03-22-2013)
Old 03-22-2013, 04:25 PM   #3
Thank you for the quick reply, joecaption!
Those are pretty good and wide variety of possibilities that you have mentioned.
There have been similar seasonal thaws and heavy rains in the past few years and I don't think we had this problem except this year.
Is it possible to narrow it down to anything particular?
Any help would be most welcome.
Old 03-22-2013, 05:25 PM   #4
take a hose outside and start spraying down low at the foundation wait 30 minutes if no water keep moving up until you have water and thats your problem
zcs20027 is offline   Reply With Quote
Old 03-22-2013, 05:36 PM   #5
Thanks zcs20027.
Sorry to sound dumb, what exactly do you mean by that is the problem?
Old 03-23-2013, 09:32 AM   #6
Rewards Points: 142
like joe said = keep the water away from the house in the first place. then there will be no water to get in.
Fix'n it is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Water Leakage Under Basement Window Well Slomarmoreno Plumbing 2 09-18-2012 06:40 PM
Water leaking in through door on main floor down to basement. DIYinTraining Building & Construction 15 12-14-2011 07:24 PM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 09:34 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
