Water in the basement
If you have puddles, it could have been due to water intrusion caused by downspouts not extended away from the house, along with clogged gutters. If the sump was off for only two hours, unless you had a river rushing in, it would have been fine. The one thing you do not want, is the sump getting knocked out more than 3 to 4 hours if you are on a high water table.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
