Washers For Bolts Used In Sistering - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 08:08 PM   #1
Question
Washers for bolts used in sistering
Old Geezer that I am, the following info would be welcome. I plan to bolt sisters to 7 beams/floor joists. The beams a just a little less than 8" and a little more than 2 1/4" or 2 1/2 inch. So far the bolt dia. will be 5/16". I plan to use 6 washers per bolt, 5/16, 7/16, & 7/8. Is this considered optimum/correct? One each of the previous on each side, plus construction glue.
BluGator is offline   Reply With Quote
Old 01-19-2012, 08:16 PM   #2
Rewards Points: 14,014
Your post makes 0 since to me, why all the washers?
Use 1/2 carrage bolts not 5/16 and you will only need one 1/2 washer.
Old 01-19-2012, 08:20 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I've never heard of needing sistered joist for just an 8" foot span. Even a 2 X 6 can span that far, what's up with that?
I think he is saying the joists are 2-1/2" by 8". He doesn't say how far they are spanning.
titanoman is offline   Reply With Quote
Old 01-19-2012, 08:51 PM   #4
Opps your right I need to get new glasses.
So what do you think about the rest of his ideas?
Old 01-19-2012, 08:55 PM   #5
Disabled wood vet
titanoman's Avatar
I think he just needs fender washers if he's wanting to put bolts into rotted wood. Other than that, I don't know what he's thinking.
Old 01-19-2012, 09:02 PM   #6
Question
Washers for sistering bolts
Sorry for the misconception (sp). The original joists are mid to late 1800's. They very from 7' to over 24' in length. They are 2 1/4" wide to 2 1/2" wide. Their are 7 3/4" high. They had notches cut in them in 1930 when plumbing was added to the house. The notches were cut by plumbers. We are attempting to sister 7' lengths. The washers are to preclude damaging the sister and original joist beam. A precaution noted on another web site. I need to find out the three staggered dia. Any ideas?
Old 01-19-2012, 09:17 PM   #7
Are you aware a 2 X 8 is only good for about a 7 ft. or less span?
http://www.awc.org/calculators/span/...orizontal+Span
Old 01-20-2012, 11:17 PM   #8
Registered User
Rewards Points: 526
"I need to find out the three staggered dia. Any ideas?"------ I don't know where you got that information....
As Joe said, 1/2" are usually used as a minimum. The washers fit the bolt, one on each side for max. strength. Stacking the washers in varying sizes does nothing. Bolt just the ends if using the sister for carrying the whole load, bolt in a staggered pattern down the length for helping the original (both joists) carry the load, there are restrictions and further help we can supply.
2 x 8 are fine sistered to old, #2 grade will span 10', only a #3 grade won't--- 40# per square foot chart, find the grade and species: second chart down; http://publicecodes.citation.com/ico...002_par017.htm
Gary
Old 01-21-2012, 07:21 AM   #9
Thanks everyone. We accomplished most of the sistering yesterday. I would take me a small book to totally explain everything we have done. Your responses have been helpful. Stay out of the snow, freezing rain, and rain. Keep warm.
Old 01-21-2012, 08:17 AM   #10
Retired carpenter
Adding gradually larger washers will decrease the pressure on the wood around the bolt. (I would also use just 1/2" bolts with 1/2" washers, and if the wood gets a bit crushed under the washer, so be it.)
abracaboom is offline   Reply With Quote
Old 01-21-2012, 08:35 AM   #11
Disabled wood vet
titanoman's Avatar
How would it decrease pressure? Wouldn't the pressure transfer through any amount of washers?
Old 01-22-2012, 02:39 AM   #12
Retired carpenter
The same force applied over a larger area means less pressure. Pressure equals force over area (pounds per square inch). Same force, more square inches: less pressure.
Old 01-22-2012, 07:50 AM   #13
Disabled wood vet
titanoman's Avatar
That makes sense. Thanx.
Sistering Bouncy Floor Joists SimpleFix Building & Construction 28 10-08-2012 05:52 AM
sistering joists micparks Flooring 6 12-30-2011 09:18 PM
80-year-old apartment buildings, washers, DFU values, FUD WillisBlackburn Plumbing 4 09-18-2011 05:25 PM
Can two washers drain into one utility sink? mcru Plumbing 6 07-26-2010 08:23 PM
Sistering a floor joist? teachtech Building & Construction 8 02-19-2008 09:35 PM
