Washer & Drier Platform - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 02:57 PM   #1
Has anyone built a platform for a washer & drier? If so, where do I begin?... I was thinking...
Start by building it from 2x10's so it is really strong. Attach it to the 3 walls & floor. Then cover that with 3/4" plywood. Then everything, including the floor gets covered in slate flooring material...
Seems easy enough but I'm afraid to start until I get some feedback...
Thanks in advance!
MsFinnegan is offline   Reply With Quote
Old 10-06-2011, 03:00 PM   #2
DIY staff
Rewards Points: 7,174
I've built two of them using 3/4" cabinet ply with 2x4 blocking glued and screwed into all joints---worked fine.
MsFinnegan (10-07-2011)
Old 10-06-2011, 04:37 PM   #3
kwikfishron's Avatar
Rewards Points: 618
There’s no reason to use 2x10 unless for some reason you want the w&d that high off the ground.
kwikfishron is online now   Reply With Quote
Old 10-06-2011, 04:49 PM   #4
DIY staff
Ron--Those front loader washers are typically set on risers 14 to 16 inches tall----the optional ones from the manufacturer are big bucks---so home made ones are common.
Old 10-06-2011, 04:58 PM   #5
Rewards Points: 618
Wasn’t thinking about front loaders and your right about the crazy price of the stands.
If I was going to go up that high I’d build a pony wall.
Old 10-06-2011, 10:19 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
I built one....had a pull out drawer in it. Made pretty much the same way Oh Mike made his...except I used 2x2....
Center does not have to be real strong...the feet of the washer or dryer are near the corners....
Keep it simple....glue and screws work well. Don't use nails...the vibration could work them loose.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 10-07-2011, 08:17 AM   #7
I've done a few out of refridgerator uppers to match the cabinetry in the laundry room.
RTRCon is offline   Reply With Quote
The Following User Says Thank You to RTRCon For This Useful Post:
oh'mike (10-07-2011)
Old 10-07-2011, 09:29 AM   #8
Thanks everyone! I'd LOVE to add drawers for extra storage but that may be more than I'm capable of doing on my own... Any suggestions on that? Do you recommend I build it in place? The thing is I'd have to take the front load washer/drier out of the room, build it all & slate it before I could put it all back, and that could take a while...
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 10:40 PM
