Warehouse Racking Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2012, 12:18 PM   #1
Warehouse racking installation
I have some basic tear drop warehouse racking i need to install my self instead of contracting out like I have in the past. I know how to build the racking but i dont know what tool i would need to shoot the bolts into my cement floor. Would I use an Impact wrench? I just dont know.
KJKerns3 is offline   Reply With Quote
Old 04-09-2012, 12:24 PM   #2
DIY Enthusiast
sublime2's Avatar
You will need a corded rotary hammer drill and concrete bit.
Then hammer bolts into the ground. Line up hole in rack with bolt and secure with the nut that comes with the bolts.
sublime2 is offline   Reply With Quote
Old 04-09-2012, 12:29 PM   #3
Rewards Points: 12,808
See if this helps.
I've always used a core drill and set the bolts in epoxy.
Home Depot rent this style drill, there not cheap to buy.
Old 04-09-2012, 12:34 PM   #4
DIY Enthusiast
sublime2's Avatar
Originally Posted by joecaption
See if this helps.
I would NOT do what they are doing in the video in as far as climbing on the racks without them being secured to the ground.
Old 04-09-2012, 12:36 PM   #5
http://stores.toolsdirectusa.com/-st...Categories.bok
Old 04-09-2012, 12:43 PM   #6
DIY Enthusiast
sublime2's Avatar
Little overkill IMO. Guess it depends on what you plan on storing on the racks........
Old 04-09-2012, 12:54 PM   #7
Light inventory. Mostly skids of blank cardboard boxes for packing. it doesnt need to be extremely secured. The cement floor I have will be good enough to bear any load and bolt size. I just dont want it moving around on the floor if it gets any little bumps from the lift trucks.
Old 04-09-2012, 12:57 PM   #8
DIY Enthusiast
sublime2's Avatar
Rotary hammer drill will do fine.
You can also rent them from HD if you don't have one.
Just be sure to secure all legs of the racks.
Old 04-09-2012, 01:04 PM   #9
Thats what Im going to do. I dont even really know what process is involved in using the hammer drill. Im sure I'll get it running just fine. I just dont know exactly what bit, or what kind of bolts or any of the supplies I'll need. The process will just have to come to me as i go unless someone has some detailed instructions for me. lol
Old 04-09-2012, 01:07 PM   #10
Also, whats a good make/ model for the job. my boss will spring for pretty much whatever I say I need so i figure i may as well get it done right.
Old 04-09-2012, 01:08 PM   #11
DIY Enthusiast
sublime2's Avatar
Based on your comments you WILL be renting one.Tell the people that you rent the drill from what your plans are.
They will guide you on what you need to accomplish it and how to do it.
Old 04-09-2012, 01:25 PM   #12
Whats my best bet for the drill? make/ model?
Sewage grinder pit and pump installation leff1rj Plumbing 15 02-04-2011 12:36 PM
casement windows installation versus double hung installation user82106 Building & Construction 2 06-16-2010 06:56 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
