-   -   want to remove loadbearing wall (http://www.diychatroom.com/f19/want-remove-loadbearing-wall-122933/)
danieldowns 11-09-2011 08:34 PM
I want to remove this load bearing wall(see photos) I have had extremely high estimates($1400) for an engineer for this project to determine necessary beam etc.
Is it safe or possible to remove a section from window to window(removing windows) a header to support load? thanks for your advice and http://i43.tinypic.com/2n6olh.jpg http://i43.tinypic.com/2s7batu.jpg a header to support load? thanks for your advice:whistling2:
http://i41.tinypic.com/28v9f9.jpg
sixeightten 11-09-2011 08:37 PM
Nothing like saving fourteen hundred bucks on the internet.
woodworkbykirk 11-09-2011 10:19 PM
forget about hte internet.. consult the engineer. if anything ever happened and you didnt use an engineer , its your A$$ on the line and your insurance wont cover you.. if the engineer spec's something that fails well he pays for it
just shop around LOCALLY to see if you can get a better price
1910NE 11-10-2011 07:13 AM
I don't know if 1400.00 is expensive for your area or not for an engineer to figure out and stamp your plan. It's also pretty hard to grasp what you are asking about from the pictures you posted, as they are pretty big. Are you talking about removing some (all?) of the wall between the enclosed porch and the interior room?You might want to re size them, with some descriptive captions for each.
Or not. What you really need is the engineer.
Daniel Holzman 11-10-2011 08:02 AM
You state you got an "estimate". An estimate is not a firm price, it is not a bid, it is simply an estimate. If you want a firm price, you need a "bid", which in engineering lingo may be called a quotation. Or a contract offer. As you find the estimate extremely high, you should consult with other engineers in the area.
As a personal note, I generally avoid working for homeowners, as many of them feel the same way you do, i.e. my prices are too high. So allow me a little space here on the subject of engineering prices. I have a professional engineer's license, and am a certified cost engineer. I have been doing this for 30+ years. When I do structural engineering jobs for insurance companies, I charge $125 per hour, and that is pretty standard in our industry.
If I applied the same standard rate to a homeowner job, lets look at the time to design a header. There is a site visit, probably at least 1.5 hours travel there and back. Yes, I charge for my travel time. There is the on site consultation with the homeowner, where we discuss alternatives, such as steel vs. conventional lumber vs. laminated versus flitch beam etc. Figure an hour to discuss options, including support alternatives. I have to sketch up all the framing, which may require opening a ceiling or a floor. Figure at least an hour or two for that. I have to size the header, and draw the connection details. Figure 2-3 hours for that. Usually I have to stamp a drawing for submittal to the building department. I always discuss the project with the contractor to make sure the contractor understands all of the details, and to remind the contractor about the need for proper temporary support. I always offer to meet the contractor on site the first day to verify that the construction meets the design.
All told, this can come to 10 hours easily, which makes $1250 at my standard rate, plus mileage (yes, I charge for mileage). The majority of homeowners feel this is excessive, hence I RARELY work for homeowners, else I do it at a reduced rate when I have no other work available. So do I think the rate you were quoted is outrageous? Not if the engineer is offering a similar scope to what I generally offer. However, there may well be structural engineers in your area who are short on work, and will take the project at a discount to their normal rate. Getting a good deal on design work is not immoral, illegal or fattening, it is prudent on your part, so I suggest you shop around a bit. You may even find someone on an internet chat group willing to size the beam for you. Miracles do occur.
danieldowns 11-12-2011 03:05 PM
thanks
thanks for your replies. I will shop around a little more for the engineer. Sorry for the big photos.
