Want To Build A Covered Porch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 10:30 AM   #1
want to build a covered porch
My cement and tiled uncovered porch was built in the early 1970s and I am pretty sure it is being supported by rebar. I want to know if this is sufficient to support my covered porch (with 4 columns). The porch as it sits now is flush against the house with only one crack that has appeared in the cement.
marco fortino is offline   Reply With Quote
Old 07-23-2010, 05:58 PM   #2
DIY staff
Rewards Points: 7,174
Where are you located?
A short answer is no. Check your local building code.Typically any thing attached to the structure(house) needs footings deep enough to avoid frost heave,and large enough to hold the weight of the new porch cover.
Covered Porch over Basement leaks/rotting/repair Old College Try Building & Construction 10 11-13-2013 09:37 PM
Adding on covered porch... callkenny Building & Construction 0 03-07-2010 11:50 AM
covered concrete porch..what kind of floor? captjackny Flooring 4 02-26-2010 10:47 AM
Water problem in Florida -Will Covered Porch Help? Tally_Lassie Building & Construction 8 09-28-2008 07:01 PM
Replacing covered porch support posts yousah Remodeling 4 09-30-2007 12:15 PM
