Want To Build 10x16 Deck With Ramp - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2013, 12:37 PM   #1
Rewards Points: 588
want to build 10x16 deck with ramp
Next time I have a few days off in a row I want to build a deck on my shed with a ramp going down the lowest side. Im nor sure if I want to attach it to the shed or not yet. I'm leaning towards free standing to maybe avoid removing the siding from the shed. If I go free standing I'd still like to attach it to the shed somehow so that over time a gap between the doors and deck wont appear. Any ideas/opinions on this? This will be my first time ever building a deck so pointers are welcome.
I plan to use 4x4s since its only gonna be about 3' off the ground at the highest point. Should I use 6x6s? How do you guys notch the 4xs/6xs to lay the 2x6 across? Would a sawzall work or is there something easier?
nikeman is offline   Reply With Quote
Old 09-17-2013, 03:35 PM   #2
Rewards Points: 3,130
Download this: www.awc.org/publications/dca/dca6/dca6-09.pdf It will answer a lot of questions you may have. As for notching the posts, I use a circular saw for most of the cutting, and finish up with a hand saw. It's a lot easier to get straight cuts that way than with a Sawzall (at least for me).
Around here, if any portion of a deck is more than 30 inches off the ground, a railing is required.
Old 09-17-2013, 05:53 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
back for another project I see
did you ever post any final photos of your deck?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-17-2013, 09:42 PM   #4
Rewards Points: 588
I think I did. This time its all on me. I want to learn how to do it myself so I don't have to pay anyone.
Old 09-21-2013, 06:36 PM   #5
Rewards Points: 588
Should I use 6x6 posts? I have decided to go free standing with 8 total posts (4 right up against shed and 4 more about 8-10' out. I'm leaning toward 8' now just to have less cuts when hanging the joists.
Old 09-22-2013, 06:30 PM   #6
Rewards Points: 588
Another quick question. Should I use bigger than 2x6 joists? I'll be driving my riding mower on the deck but its not real crazy heavy (I can lift the back tires off the ground by hand).
Old 09-23-2013, 07:49 AM   #7
Considering the small cost difference, I'd go with 2x8 joists. Overkill? Perhaps, but why be sorry later that you didn't do it?
Old 09-26-2013, 03:08 PM   #8
Rewards Points: 588
I keep walking around home depot and stopping at the concrete tubes and can't help to think that they may be the easiest thing to use to build this deck. What do you guys think? I have never used them before and am wondering how i'de attach the rim boards to them but I think that they would be easier to make level on the hill I am building on since I can just bury them all a certain depth and then bust out the string level and cut the cardboard down to where its level, fill with concrete and be done....
Old 09-27-2013, 11:00 PM   #9
Rewards Points: 588
Would 3 posts across for a 16' wide deck be enough? 6 posts all together with 2x8 joists.
DougFir Deck - Stain Before or After build? mntnvew Carpentry 15 06-09-2015 12:55 AM
Cedar deck help mickbiv Painting 11 08-08-2013 10:21 PM
deck with handi cap ramp costs? Dan Jennings Building & Construction 3 11-05-2012 02:36 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
