Walls In The Wind - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 06:13 AM   #1
Walls in the wind
I own an older house and when the wind blows the walls move and make noise. How can I correct this problem?. Help!!
papplesnap is offline   Reply With Quote
Old 06-12-2010, 06:30 AM   #2
My first thought would be the installation of sheathing or let-in bracing
RoyalAcresRod is offline   Reply With Quote
Old 06-12-2010, 06:54 AM   #3
There is evidence that the sheet rock nails are be loosened by the outer wall movement. The siding is still on the house. Any more ideas would be appreciated. Thanks for your reply.
Old 06-12-2010, 07:01 AM   #4
I am a novice carpenter at best. Please be very clear with ways to repair this in replies. Thanks again.
Old 06-12-2010, 07:03 AM   #5
Is there sheathing under the siding? I the walls are moving, they are improperly built. There's really no simple answer or magic bullet to correct this without investigating the construction methods utilized.
Correcting this will probably entail removing the siding or drywall....and will give you the opportunity to insulate correctly.
The Following User Says Thank You to RoyalAcresRod For This Useful Post:
papplesnap (06-12-2010)
Old 06-12-2010, 07:09 AM   #6
I Thank You very much for your reply. I will keep you posted on the progress. I thing this house was very poorly constructed in the first Place. Thanks again.
Old 06-12-2010, 07:23 AM   #7
Old School
Willie T's Avatar
Here's the concept: (Use the <CONTROL> key and the "+" key, together, to enlarge.)
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
Old 06-12-2010, 07:33 AM   #8
Thank You that explains the concept very well.
Old 06-14-2010, 09:44 AM   #9
Tool Cop
That was my thought too. Sounds like it's going to be a large job to even figure out what is causing this. Perhaps using some blow in insulation will help you from having to tear down the walls completely.
TrafficCopSmith is offline   Reply With Quote
Old 06-14-2010, 12:40 PM   #10
Your house sounds like it is structurally unsound, and dangerous.
http://answers.yahoo.com/question/in...7104713AARLzHu
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
Insulating walls for heated garage Huskie Building & Construction 5 09-19-2009 12:54 PM
Installing Plumbing in 2” Wide Walls? Robert1_1 Plumbing 5 09-16-2009 08:43 AM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 03:07 PM
Moisture on walls chrisr Building & Construction 1 01-20-2008 09:37 AM
