Walls Open- New Or Replacement Windows? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 07:07 AM   #1
sweaty
Rewards Points: 276
Walls Open- New or Replacement Windows?
We're renovating our old kitchen and bathrooms and the drywall will be removed on exterior walls. Is it a good time to replace the windows? We're on a budget, but want to do things right. Can they be new construction windows or must they be replacement windows? We have aluminum siding.
sweaty is offline   Reply With Quote
Old 08-07-2011, 08:55 AM   #2
Rewards Points: 5,336
If you're renovating, it's a good time to replace the windows, especially if you're using new construction windows. What you use will depend on the siding detail and how involved the process will be, along with what type windows you have now. If you have double hungs in place, with the aluminum right against the window, I'd go with replacement windows. You'll have a hard time getting aluminum siding to match what's currently on the house, if you can find it at all.
Post some photos of the exterior and the open walls.
Ron
B. Franklin 1759
Old 08-07-2011, 09:20 AM   #3
Framing Contractor
If you use replacement windows it's a lot cheaper. They're are some very good replacement windows out there. New windows mean you have to rip out the old window and frame plus the siding around the outside. Alot more time/money and material.
Joe Carola
Joe Carola is offline   Reply With Quote
Replacement windows not going to work? AnthraciteDude Building & Construction 9 12-10-2010 11:43 PM
Replacement Windows? Asbestos Shingles? I have NO CLUE! Evil Scotsman Carpentry 2 10-19-2010 12:01 PM
Can't open Milgard Aluminum Single hung windows riverjamie Building & Construction 2 01-19-2010 05:15 PM
Replacement vinyl Windows (Measurement / ordering question) DyerWolf Remodeling 5 10-02-2009 07:54 PM
