Wallboard Type - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2008, 12:28 AM   #1
analogmusicman's Avatar
Rewards Points: 560
wallboard type
I know that kitchen paint should be enamel to resist moisture. what about the wallboard underneath? should it be the "green" kind you use in bathrooms? if the answer is yes (hope it's not :-) then how about this: I'm converting a room in the basement into a kitchen, the wallboard that's already there must be the regular kind since it was finished as an exercize room. if the answer is no and regular wallboard is ok, then what about behind the sink? should there be a "backsplash"?
tnx,
analogmusicman is offline   Reply With Quote
Old 02-19-2008, 08:16 AM   #2
Regular drywall should be fine, and a backsplash should be at least 4"along countertop with sink.
hammer is offline   Reply With Quote
Old 02-19-2008, 10:41 PM   #3
remodeling pro
Regular wall board is fine, and the idea that kitchen paint had to be enamel is a little used holdover from the old days, when enamel was used because the walls and ceilings in kitchens had to be frequently scrubbed to remove grease and cooking residue, which built up quickly because of poor, or most frequently , no ventilation equipment.
Like hammer said, you definately want a backsplash behind all the work surfaces.
troubleseeker is offline   Reply With Quote
Old 02-20-2008, 04:24 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Regular sheetrock = fine
- Build Well -
Copper pipe type for residential water distribution BigJimmy Plumbing 7 12-31-2007 09:39 AM
what type of coating for flat roof kenny357 Roofing/Siding 5 06-25-2007 05:47 PM
What type of wallboard? woodeagle Painting 2 01-12-2007 11:53 PM
Comment on those Special Type of Treated Wood for Deck ? KUIPORNG Landscaping & Lawn Care 4 07-04-2006 01:38 PM
Type L Or M Copper Pipe bobo Plumbing 1 11-20-2005 08:53 PM
