Wall Vent For Over The Range Microwave - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-28-2008, 05:30 PM   #1
Wall vent for over the range microwave
I am remodeling my kitchen and had new cabinets put in.
There was an existing hole for the range hood vent that was there before. However, the new cabinets are in a slightly different spot and the new microwave needs to vent in a different spot.
Here is a picture:
I'm wondering if I can just line the whole thing with tin and let it vent out that way or something similar?
I don't want to do any work on the outside of the house if possible.
Thanks in advance.
JoeClark is offline   Reply With Quote
Old 11-28-2008, 11:09 PM   #2
Rewards Points: 1,574
I'm no tin man but it looks from your picture like a wall stud was cut to install the original vent. I would assume that should be fixed before anything else.
On my recent remodel, the vent from the microwave oven was in the center of the oven and given the scant amount of room between it and the wall , I don't know how you could offset the vent to the existing vent. Might have to move it.
Good luck.
bob22 is offline   Reply With Quote
Old 11-29-2008, 08:37 AM   #3
Rewards Points: 5,336
You really have no choice about the outside work. The vent opening needs to be where it needs to be. There is no ,"tin" work you're going to do, to avoid the inevitable.
Ron
Old 11-29-2008, 01:11 PM   #4
That's what I was afraid of.
Thanks for the info.
I might have to go with recirculation for now instead of the vent.
Can't remove Whirlpool Over the range Microwave kzukowski Appliances 18 06-18-2016 05:20 PM
Thru wall vent question phillyexplorer HVAC 5 10-11-2008 10:50 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Minimum Clearance to Vent Inside Wall? MikeinBurien Plumbing 12 12-06-2005 12:03 AM
