Wall Tiling - How Heavy It Can Hold - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-31-2011, 10:47 AM   #16
Rewards Points: 18
Thank you all!!
I'm sure this is going to be a messy job..
I have kids running around.. so.. this is going to be my spring project.. In the mean time I'll try to getter as much information as possible..
I know I'm asking the same questions over and over again.. but some suggest to use plywood screw them onto the studs.. is it any better over cement board?
I also like the idea of overlaying 1/4" cement board thank you!!
This is what I most likely will do.. I'll screw&glue one more 2x8 floor joist adjacent to the existing 2x8 to add more strength the to floor.. and will cut out the existing wall and use cement board instead..
but here.. should I be using 1/4" board or a thicker??
here are pictures of stones I've purchased and 3 bags of mortar..
zzeuss is offline   Reply With Quote
Old 12-31-2011, 11:15 AM   #17
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Half inch cement board must be used on wall studs.
XXX
Old 12-31-2011, 09:47 PM   #18
Rewards Points: 18
got it..
thanks again.. i just have to find a time to remove the wall now...
Old 12-31-2011, 10:17 PM   #19
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Be sure to first cut the ceiling juncture. A deep deep cut to the juncture with a utility knife would be the thing to do.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
zzeuss (12-31-2011)
Old 12-31-2011, 10:26 PM   #20
Rewards Points: 18
Thanks again..
Happy New Year.. ALL..!!!
Old 01-01-2012, 12:42 AM   #21
Rewards Points: 150
Go with the cement board, screw fixed over the drywall to the studs. The reason for the cement board is that adhesives have been formulated to stick to cenent board better than painted plasterboard, as any tiler will attest. The cement board doesn't rot or form mould if it gets wet, in any case, no where as much as drywall would, that's why it is most often used in wet areas like bathrooms. A lot of tile adhesives are cement based.
The weight of the wall is not significant. 14llbs/sq ft dead load is distributed over the whole room floor, so the wall alone is minimal. You would also have to cram 60 beefy people in the room to exceed the floor live load capacity at between 40-60 llbs/sq ft. Unless you run a sweatshop, this is unlikely.
Cheers and a Happy New Year to you and all the readers. Joe in Oz.
JoJo-Arch is offline   Reply With Quote
Old 01-01-2012, 08:01 AM   #22
Rewards Points: 18
Another great info.. Now I feel more confident...
Thank you everyone..
Tiling a slanted wall around a tub kadacd Remodeling 3 01-12-2011 03:32 PM
Tiling under outlet wall plate??? mjkpainting Tiling, ceramics, marble 3 06-23-2009 07:16 AM
tiling - How difficult to remove from a wall? popiesbaby Kitchen & Bath Remodeling 3 12-19-2008 10:46 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
