Wall Stud Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 07:57 PM   #1
Wall stud replacement
I am replacing some and sistering some wall studs and the sill thanks to termite damage. Should I use regular wood or salt treated wood for the new studs/sill?
Michelle D is offline   Reply With Quote
Old 07-27-2010, 01:50 AM   #2
Rewards Points: 1,092
Michelle: I'd advise asking a bug specialist in your area. Termites are a PITA. I know there are metal flashings made specifically to deter termites, as a first line of defense, and there are non-earth-friendly poisons for the suckers. You may have to repeat treatments periodically, too; I've had to do that w/ carpenter ants (synthetic pyrethroid nuked them immediately, then I retreated prophylactically (sp?) two years later.) GL. j
Old 07-27-2010, 05:51 AM   #3
Anything touching concrete should be pressure treated. But since you have an issue with termites, I would at least replace the bottom plate with PT. Borax treatment works well on most insects.
Keep in mind that ACQ treatment requires special fasteners, with stainless steel being preferred.
Old 07-27-2010, 08:09 AM   #4
The house has already been treated for termites and there is no more activity. I need to know what kind of wood to use. What is PT?
Old 07-27-2010, 01:38 PM   #5
PT is pressure treated; All Weather Wood. Usually a bronze color; used to be green. It will eat ordinary nails in a few years, hence either galvanized or stainless steel are used. Glad your 'mites have been treated.
The Following User Says Thank You to jklingel For This Useful Post:
Michelle D (07-27-2010)
range hood through the wall - - -stud in the way pacifier1er Building & Construction 30 05-21-2013 09:23 AM
Removing one stud from a bearing wall. tigereye Carpentry 10 03-28-2009 02:02 PM
Move a wall stud dcav Building & Construction 11 03-12-2009 12:42 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Removing a stud, not damaging "back" wall JoshuaBaron Building & Construction 13 02-23-2009 09:28 AM
