Old 07-05-2009, 05:49 PM   #1
wall shower rack in ceramic tile
I need to install shower caddy type rack in shower that has ceramic tile. The racks came with screws and plastic anchors that look like they are for drywall installation. I need to know if these anchors can be used? I fear they might expand too much and crack the tile.(wife not happy at all). Can i just use the screws in the tile? I need some help on this cause as all you guys know i cannot screw this on up. Thanks in advance.
ProudMarineDad is offline   Reply With Quote
Old 07-05-2009, 06:50 PM   #2
Plastic inserts are good for tile. I've used them and never had a problem. I would suggest positioning the caddy so that the anchors are not right on the edge of a tile. That could cause a problem. Also It would be good to put a dab of silicone over the anchor before you install the caddy so that it will be sealed.
Good luck
Jesse Pender
Portland Tradesmen
www.portlandtradesmen.com
Portlandtrades is offline   Reply With Quote
Ceramic tile over subfloor in Kitchen pinkertonpv Flooring 11 01-12-2013 01:40 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Tile in Shower and on Wall of Bathroom jwhiteuwc General Discussion 2 02-02-2009 09:21 PM
help- it's more than just a tile fallen off the shower wall! infantrymama General Discussion 7 05-27-2008 11:06 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
