-   -   wall shower rack in ceramic tile (http://www.diychatroom.com/f19/wall-shower-rack-ceramic-tile-48159/)
ProudMarineDad 07-05-2009 05:49 PM
I need to install shower caddy type rack in shower that has ceramic tile. The racks came with screws and plastic anchors that look like they are for drywall installation. I need to know if these anchors can be used? I fear they might expand too much and crack the tile.(wife not happy at all). Can i just use the screws in the tile? I need some help on this cause as all you guys know i cannot screw this on up. Thanks in advance.
Portlandtrades 07-05-2009 06:50 PM
Plastic inserts are good for tile. I've used them and never had a problem. I would suggest positioning the caddy so that the anchors are not right on the edge of a tile. That could cause a problem. Also It would be good to put a dab of silicone over the anchor before you install the caddy so that it will be sealed.
Good luck
Jesse Pender
Portland Tradesmen
www.portlandtradesmen.com
