Wall Sheathing Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-03-2013, 10:22 PM   #1
wall sheathing question
When sheathing walls is it necessary to sheathe the corners as you tie the walls in?
markharmon is offline   Reply With Quote
Old 07-05-2013, 09:26 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
usually corners are lateral supportive so need sheathing at least 4' out from corner. the corners can be sheathed afterward up in the air if pre building walls on the flat and if the sheathing interferes with standing the wall...
hand drive is offline   Reply With Quote
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 10:37 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
