Wall Sheathing Question - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 10:27 AM   #31
Originally Posted by hand drive View Post
when putting hardie siding as the siding on the wall I always put the foundation plate about 1/2" back from the edge of the foundation and this flushes out the sheathing with the foundation and the the hardie laps down 1" onto it. hold sheathing 1/4" up off of foundation so no wicking occurs etc...
Here is another thing I see that I dont understand. When i put up my soffit panels and attach a j or f channel to the end wall how do I get my vinyl siding into that channel as well. I see pictures of soffit and vinyl siding and I only see one channel for the soffit.
markharmon is offline   Reply With Quote
Old 05-06-2013, 10:35 AM   #32
AHH, SPANS!!!
Rewards Points: 1,166
a lot of times you work the soffit panels from one side and slide them down the line, leave a cornice off of one side of overhang and slide in your soffit panels there and once the soffit is all filled in put on your cornice.
oops, edit. I think you use another J up side down for the siding and another facing the soffit for the soffit- been so long since I've touched vinyl siding... there is the little termination piece that works at the top of a cut piece of vinyl siding also that laps up into the J channel.
hand drive is offline   Reply With Quote
Old 05-11-2013, 02:43 PM   #33
GBrackins's Avatar
Rewards Points: 2,108
but what if I choose brick.
sorry Mark I missed the question in regards to brick. if you wanted to have real brick then your foundation typically would have a brick shelf. This is typically (depending on your brick, air space and any rigid insulation board) 4" so that the foundation can support the brick.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Simple question regarding Wall Switch wiring kebrein Electrical 6 11-25-2011 08:54 PM
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 10:37 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 01:02 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 06:39 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
