-   -   wall sheathing question (http://www.diychatroom.com/f19/wall-sheathing-question-178765/)
markharmon 05-04-2013 07:50 PM
Hi guys,
I have some quick questions. When you have your 8" thick foundation wall should you install your sill plate recessed in a bit to account for sheathing and an space for the sheathing to rest on? Or should the sill plate be flush with the outside of the foundation wall? Same with rigid foam do you set the sill back to account for the rigid foam as well?
GBrackins 05-05-2013 12:23 AM
sill plate should be about a 1/4" past the outside edge of the foundation. you do not want your wood sheathing against the concrete as it may wick water. at least that's how it's done in my area
woodworkbykirk 05-05-2013 06:16 AM
gb is right, the reason is to create a drip edge of sorts. .when water runs down the wall it runs down past the joint between the plate and the foundation so it bypasses that joint and doesnt run into the house
markharmon 05-05-2013 07:48 AM
1/4" past or in from the outside edge? What about if you have rigid foam? Does that start from the sill and go up and just overhang at the bottom?
MJ Force 05-05-2013 08:39 AM
Generally you place the sole plate flush with the edge. In most cases there will be a channel or rabbet where the leveling strip for the foundation wall was placed. Your sole plate sits at the edge of the rabbet and on top of a sil gasket of course. Your subsequent layers of sheathing and siding will step the building envelope away from the concrete wall. Do not let the sheathing touch the concrete. It only covers the sole plate. Your final siding should be stepped slightly lower than the previous layer. A 1/4" to 1" lower for each layer depending on the materials and method used.
If your really worried about it or if you get heavy rains, place a small drip flashing between the siding and the previous layer to kick out any water running down.
GBrackins 05-05-2013 11:54 AM
the sill plate (which is attached to the top of the foundation with anchor bolts) overhangs the exterior side of the foundation 1/4". you do not want your wood sheathing in contact with the foundation
markharmon 05-05-2013 01:45 PM
MJ says keep it flush and you say to overhang it 1/4"?
markharmon 05-05-2013 01:50 PM
How come GB is saying to extend it over 1/4" What do you mean by will step the building envelope? I guess my whole thing is when you leave the sill plate flush with the edge of the foundation wall and and sheathing, wrap, rigid foam and siding and you look up from under all of this what covers it all? Its not going to down to below grade or anything where you back fill it obviously.
jsbuilders 05-05-2013 02:19 PM
What kind of siding are you using?
GBrackins 05-05-2013 02:40 PM
I'm saying this is how it is done in my area. we overhang the sill plate a 1/4" so that the wood sheathing is not in direct contact with the concrete at grade level, the sheathing can wick water which will lead to rot in time (unless you use preservative treated wood, so why have that expense?). overhanging the sill plate leaves a void between the face of the foundation and the back of the sheathing, make sense?
markharmon 05-05-2013 03:41 PM
For example vinyl but what if I choose fiber cement or even brick. I mean if your overhang the sill plate past the foundation wall there is going to be a gap underneath am I right? What is going to cover that?
jsbuilders 05-05-2013 03:53 PM
Of your really worried about it bend some PVC coated aluminum coil stock (color matched to your siding).
jsbuilders 05-05-2013 03:54 PM
Originally Posted by jsbuilders (Post 1173160)
If you're really worried about it bend some PVC coated aluminum coil stock (color matched to your siding).
Sorry I'm on my phone
MJ Force 05-05-2013 06:18 PM
This way is correct also.
In my area the bottom plate is flush with the concrete. I just looked at the plate on my home and its done this way also. 25 yrs ago. Ive always done it like this. Each builder may make allowances for the type of siding used. The important thing is that the sheathing does not come in contact with the concrete.
markharmon 05-05-2013 06:30 PM
so you bring t sheathing down so its level and flush with the bottom outside edge of the sill? What about siding and if you want rigid foam on the outside? Does that come down to the same level as the sheathing?
