Wall Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 11:32 AM   #1
Wall Removal
Im In the process of remodeling an old style jack and jill master bathroom, its the L shaped style with a shared tub in the 90 degree area. I Want to remove the wall and doorway in between the master toilet, sink and the tub, and the wall the doorway from the other toilet sink area.
I have been researching this, and I know that the wall is parallel to the attic truss. In the attic, the wall is in between 2 truss and there a 2 2x4s laying flat where the wall is attatched! From what I have read I do not think this is a load bearing wall, but I wanted to see what you guys think. the total length includng the doorway s 60 inchs.
These are the pictures.
Wall Removal-img_20110212_110912.jpg   Wall Removal-img_20110212_120402.jpg   Wall Removal-img_20110212_113314.jpg
1stclasso is offline   Reply With Quote
Old 02-12-2011, 11:49 AM   #2
DIY staff
Rewards Points: 7,174
That sure is a partition---Pull it out.--Mike---
Old 02-12-2011, 06:45 PM   #3
Rewards Points: 1,766
Curious as to why the huge header assuming it is a non-bearing wall? Looks like a 2x12 to me from picture. Using leftovers from the job?
bob22 is online now   Reply With Quote
Old 02-12-2011, 08:37 PM   #4
Every doorway in the house has a similar header, That is what confused me! The house was build in 1964.
Old 02-12-2011, 10:08 PM   #5
Registered User
Rewards Points: 526
Yes, it can safely be removed, as mentioned already. Many framers make up all the headers for the house at the lumber pile when adding the 2x4 header filler because that is optimum height for doors and windows. (In this case). Remove the nails in the 2x4 nailers from the attic over the wall, and add cross blocking above them to keep them stationary before removing the wall plates from below. Add a drywall rip 3-1/4" wide on the ceiling where the wall was, tape and texture to match. The nailers stay there, secured to the blocking above.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
oh'mike (02-13-2011)
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Wall removal fredshoney Remodeling 4 05-10-2010 09:01 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
