Wall Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-27-2013, 10:39 AM   #16
Rewards Points: 6,652
Originally Posted by detroittigerfan View Post
Do the wall studs always have to be directly above the floor joists?
If they are load bearing, they will always be running parallel of the floor joists. If non-load bearing, they may or may not hit a joist if running same direction. Just depends on where you place it, and if it is on top of one or not.
Old 07-27-2013, 12:50 PM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 776
If a stud is dead over a joist there is no way to face nail into that joist as there is a stud where you would have to nail for it to be "face nailed". You can nail close to the joist because in this area of the USA, we have to strap upper studs, plates and joists all together, from the rafters all the way down to the bottom mud sill, which is anchored to the blocks. All you need to do is nail so the wall can't slide in or out, you don't have to worry about lift, the straps will take care of that.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-27-2013, 01:18 PM   #18
Rewards Points: 396
Originally Posted by Fix'n it View Post
load bearing = they should be. unless its an exterior wall. then the bottom plate should be on the rim joist = its fully supported throughout.
Ok so lets assume they are then face nailing the wall bottom plate won't work because you won't be hitting a joist so what is your recommendation for fastening the bottom wall plate to the subfloor and joists?
detroittigerfan is offline   Reply With Quote
Old 07-27-2013, 01:37 PM   #19
Registered User
Rewards Points: 526
Check locally with AHJ. Under IRC, studs can be off-set to allow required face nailing (not angled- #14; http://publicecodes.cyberregs.com/ic...?bu2=undefined) of the bottom plate through sub-floor into framing when over 16"oc; http://publicecodes.cyberregs.com/ic...?bu2=undefined
At 16" on center max., the single bottom plate and the structurally rated floor sheathing carry the live loads to the next component below- to the joists/beam; http://www.trioforest.com/pdf/Load-Span_Tables.pdf
Where in Codes (other than local) do studs require direct stacking?
Gary
Open Web Truss/ Load Bearing Wall Question rlc2052 Flooring 3 03-05-2010 09:37 AM
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 12:02 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Basement knee wall question vugger Building & Construction 2 01-05-2008 09:02 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 04:18 PM
