-   -   Wall Panel Over Sheetrock in Garage (http://www.diychatroom.com/f19/wall-panel-over-sheetrock-garage-23107/)
kypper 07-02-2008 10:56 PM
The wall between my attached garage and house is sheetrocked on the garage side. I believe this is a code for a firewall. This sheetrock is getting banged up and I would like to put some wall panels over the sheetrock that are a little more durable. They are wall panels that can be glued to the wall. I would assume the panel and especially the adhesive would be flameable. Would this be allowed with the code?
Thank you in advance for any insight on this.
Termite 07-03-2008 07:57 AM
Heck of a good question. You're right that your garage is sheetrocked as a pseudo-firewall (nonrated assembly) to slow the passage of fire from the garage to the house, or the structural members that support it.
Assuming you're in a single family residence, right? If not, specifically describe the building you live in (duplex, townhome, apartment, etc).
Assuming single family house, there is not a code requirement for noncombustible construction materials in the garage. You can use wood paneling and adhesive to cover the sheetrock. The sheetrock has to be left in place though.
