Old 07-30-2009, 08:24 PM   #1
Midicat's Avatar
Unhappy
Wall Oven Box Construction
Hi Everyone,
I am installing a new Kitchenaid 30" ELECTRIC SINGLE BUILT-IN OVEN under-counter. It is designed to do this and we will be adding a compliant gas cook-top above it. My question is: what material should I build the box for the oven with? I am thinking 3/4" plywood. Any other guidance is always greatly appreciated.
Thanks,
Thomas
Midicat is offline   Reply With Quote
Old 07-31-2009, 11:36 AM   #2
3/4" plywood should be fine for the cabinet. Are you redoing all the cabinetry in your kitchen? I don't think they offer it in Home Depot/Lowes, but most cabinet manufacturers have cabinet units that are designed for wall ovens. Additionally make sure you check the specs on both units so you have proper clearance between the oven and the cook top you are installing above it.
Green Giant is offline   Reply With Quote
Old 08-02-2009, 10:35 AM   #3
Remodeling Contractor
oven cabinet construction also requires a 2X4 blocking under the support shelf and the same blocking to the floor under the shelf.
change from gas wall oven to electric runjean Electrical 3 04-19-2009 03:04 PM
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
