Wall Options For Small Bedroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 03:49 PM   #1
wall options for small bedroom
I'm converting a bathroom into a bedroom. The walls need replaced very badly. Since the room is very small, about 76 square ft, I do not want to do the normal stud construction. Are there any other options for walls. Two of the walls are exterior walls and one is the family wall between the two units (row home) so its plaster right on top of the bricks. No lathe. Any suggestions on how to make new walls without making the room even smaller?
Bigguy0 is offline   Reply With Quote
Old 01-23-2010, 03:52 PM   #2
can you get a bed in there?
Old 01-23-2010, 03:56 PM   #3
Its going to be small room so I don't want to make it even smaller. Any suggests? Does drywall have to go on 2x4s?
Old 01-23-2010, 04:01 PM   #4
your talking about converting an existing bath about 6x10? why are you adding walls, will you be adding electrical? and yes you can do 1-1/2" framing if not structural
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Modifying a wall, create opening RJA00 Carpentry 4 11-16-2009 07:59 AM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
Load bearing wall removal options ikessky Remodeling 2 08-24-2009 03:18 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
