Wall Opening In CMU - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-11-2009, 02:27 PM   #1
Wall Opening in CMU
Hi,
I have a brick fireplace in which I m installing a woodstove halfway inserted (not an insert).nd I would like to add a vent above the mantel to create a convection flow behind the stove up the flue some and through the vent back in the room.
The fireplace is a conventional red brick fireplace (in the basement) and incorporated within a CMU block wall. I d like to know what size hole I can safely make through the CMU wall and red brick flue without having to make any kind of reinforcement.
Any tips are welcomed. You can even let me know if this is worth the hassle.
Thank you
Frengineer is offline   Reply With Quote
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Looking for an opinion on what to do with a wall opening... skipjack Remodeling 7 10-20-2008 07:54 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
opening through party wall arise Building & Construction 13 02-16-2007 04:33 PM
