Wall Mounted Shelving For Aquarium - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 06:05 PM   #1
Wall mounted shelving for aquarium
I have a 15gal acrylic aquarium that I would like to put on a wall mounted shelf. Understandably, this shelving system will have to hold up at least 185lbs due to the weight of the water, the aquarium, and anything else inside the aquarium. I have identified the following as a possible option: http://www.lowes.com/pd_271768-315-1...aid&facetInfo=
Along with these: http://www.lowes.com/pd_61990-315-FG...aid&facetInfo=
The rubbermaid fasttrack rail is supposed to hold up to 1750lbs. My stud spacing is a little weird since my house was built in the 1930's... but assuming I can get this rail installed in at least 2-3 studs, it should hold the weight right?
Any advice would be appreciated. Thank you
thefixerupper is offline   Reply With Quote
Old 02-12-2012, 06:14 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I'de put legs under it anyways. Maybe the brackets can handle it, but can the wall?
If those were your kids in the aquarium you'de probably put legs under it.
titanoman is offline   Reply With Quote
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Wall mounted faucet. Charles_cz Plumbing 0 10-28-2010 06:36 PM
wall mounted toilets pittmatch Plumbing 8 02-05-2008 01:16 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
