I have a 15gal acrylic aquarium that I would like to put on a wall mounted shelf. Understandably, this shelving system will have to hold up at least 185lbs due to the weight of the water, the aquarium, and anything else inside the aquarium. I have identified the following as a possible option: http://www.lowes.com/pd_271768-315-.../pl__0__s?Ntt=fasttrack+rubbermaid&facetInfo=
Along with these: http://www.lowes.com/pd_61990-315-F.../pl__0__s?Ntt=fasttrack+rubbermaid&facetInfo=
The rubbermaid fasttrack rail is supposed to hold up to 1750lbs. My stud spacing is a little weird since my house was built in the 1930's... but assuming I can get this rail installed in at least 2-3 studs, it should hold the weight right?
Any advice would be appreciated. Thank you
