Wall Mount Tv With Metal Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By ront02769
Old 03-15-2016, 11:46 AM   #1
Rewards Points: 148
Wall mount tv with metal studs
I have a 55" led tv that I would like to wall mount in a condo. The walls have metal studs though. I was thinking of drilling a 1/2" hole through the drwall and stud, and sending through a nice big toggle bolt to catch the back of the stud. I would install 2 toggles per stud plus about 4 more toggles where there is no stud.
Does this sound good? The mount is just tilting and not articulating at all. It will be fixed in its spot and likely never adjusted once set.
Thia is the mount I am going to purchase
https://phantomcables.com/tv-wall-mo...-70-black.html
So good idea or no? Any other recomendations other than slapping a piece of plywood on the face of the drywall or cutting the drywall open to re-enforce it?
badhaircut is offline   Reply With Quote
Old 03-15-2016, 12:57 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Re: Wall mount tv with metal studs
Piece of 3/4" plywood about 12 by 18 inches. Cut out the drywall that size and screw the plywood to the studs with sheet metal screws (not drywall screws). Caulk where the ply sticks beyond the drywall and paint. Screw mount to plywood.
Coastal South Carolina
Old 03-15-2016, 02:20 PM   #3
Rewards Points: 1,442
I am suggesting twelve of the sheet metal screws. Three near the top left corner (about 1-1/2" apart), three near the top right, the rest spaced out a little more down each side.
The Following User Says Thank You to AllanJ For This Useful Post:
SeniorSitizen (03-15-2016)
Old 03-15-2016, 02:40 PM   #4
Rewards Points: 148
Do you mean to screw the mount directly to the drywall and studs with sheet metal screws?
Old 03-16-2016, 12:26 PM   #5
Rewards Points: 148
Originally Posted by badhaircut View Post
I was thinking of drilling a 1/2" hole through the drywall and stud, and sending through a nice big toggle bolt to catch the back of the stud. I would install 2 toggles per stud plus about 4 more toggles where there is no stud.re-enforce it?
Do you guys think this will hold? I will have 8-10 toggle bolts spread out evenly, 4 being through the stud.
Old 03-16-2016, 03:07 PM   #6
Rewards Points: 226
Overkill for me. If you actually get the four toggles THROUGH the face of the stud and into the hollow behind you'll be fine. Ron
Msradell and coupe like this.
ront02769 is offline   Reply With Quote
Old 06-03-2016, 08:27 AM   #7
Rewards Points: 148
Just thought I'd chime in and update this. I used 4 toggle bolts centered on the metal studs (2 per stud) then added another 3 toggles on the drywall areas. This thing is not going anywhere.
Thanks all
Old 06-03-2016, 07:40 PM   #8
KarenStein's Avatar
Rewards Points: 426
In new construction, the solution would involve placing 2x blocking within the metal studs, behind the drywall. The screws supporting the blocking only pierce the metal; the threads grab the wood.
Since you don't have that option ....
I'd use a piece of 3/4 birch (or oak) plywood, wide enough to extend to the studs on either side of the mounting bracket. I'd mount these to through-holes into the studs using what I call "molly bolts." Since I've had other folks use different names, here's a picture of one:
http://www.amazon.com/dp/B00QR2L7UC/...SIN=B00QR2L7UC
When shopping for these, you need to know the thickness of the plywood / drywall combination; there are different lengths for different wall thicknesses. As you tighten the bolts, the outer cage expands, like a mushroom, and spreads your load over a large area of the stud. It basically makes the anchor much, much fatter than the hole.
Why not use them on the naked wall? Because it's unlikely the studs match the mounting bracket, or will place the TV exactly where you want. With the plywood, you can anchor the bracket anywhere.
KarenStein is offline   Reply With Quote
Old 06-30-2016, 01:07 PM   #9
Rewards Points: 14
Hi guys ive been confused over metal studs for quite some time now any help would be appreciated.
Ive got metal studs and want to put up shelves and maybe a games console on the shelves, this comes to around 15 lbs. The shelves span 1 stud and have four fixing holes vertically, now im thinking of using either 50mm M6 lag bolts or 75mm toggle bolts.
My main concern with toggle bolts is the size of the hole, once the bolt is through the stud would it not just slip out due to the hugely oversized hole?
Im pretty confident that lag bolts would do the job for the relatively small weight, would anyone else agree?
Nishe is offline   Reply With Quote
Old 06-30-2016, 11:20 PM   #10
Msradell's Avatar
Rewards Points: 126
Toggle bolts expand after they go through the hole. Their wings expand and cannot be pulled back through the hole they were put in through. They will be much more solid than lag bolts will be. Lag bolts are definitely the wrong thing to be using for this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 07-05-2016, 03:46 PM   #11
Rewards Points: 56
subscribed, this seems like a very interesting thread
langit is offline   Reply With Quote
old pull chain metal wall mount exhaust fans mssjam Remodeling 3 10-13-2012 05:33 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 10:11 AM
metal wall studs gary d Carpentry 4 10-12-2009 09:48 AM
Plasma Mount into Metal Studs davewolfs Home Theater 24 05-21-2009 09:23 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
