Wall Layout Help - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 08:40 AM   #16
AHH, SPANS!!!
Rewards Points: 1,166
Originally Posted by markharmon View Post
And i have to notch out the top of the studs where they meet the rafters, correct?
you can or add a 2x4 under the rafter acting as a top plate and cut the roof pitch angle on the top of the studs where they butt the plate at layout. the 2x4 plate helps to straighten the rafter out too...
Do the end gable studs need to be placed directly above the wall studs from below?
Yes, just plumb up from the wall stud layout and go full to the rafter plate with the same layout. then your sheathing goes on the wall at layout to the peak. I usually turn the sheathing sideways for the gable A above the wall top plates.
hand drive is offline   Reply With Quote
Old 07-13-2013, 11:51 AM   #17
Originally Posted by TheEplumber View Post
Start your layout from the same corner as you did your floor joists.
For either the joists or wall studs- you hook your tape on the outside corner and mark 16" to the center of the joist or stud. Continue this method the length of the wall/floor.
To anchor the wall- do as previously described.
How to layout the joists and studs is not what i asked.
markharmon is offline   Reply With Quote
Old 07-13-2013, 11:53 AM   #18
Originally Posted by CarpenterSFO View Post
Do you have a rim joist or rim band? Do you have a plywood subfloor on the floor joists before raising the wall?
rim joist rim band? whats the difference?
Old 07-13-2013, 12:08 PM   #19
GBrackins's Avatar
Rewards Points: 2,108
how tall is the ridge above the floor? normally we frame gable end walls continuous from the floor to the roof (depending on height). If the gable end wall is framed separately then we use the sheathing with blocking to eliminate the hinge joint that you'd create.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-13-2013, 12:33 PM   #20
AHH, SPANS!!!
actually, under the gable walls would be rim joist and under the bearing walls would be rim band.
Old 07-13-2013, 06:41 PM   #21
Only 6' walls 7/12 pitch.
Old 07-13-2013, 06:42 PM   #22
rim joist and rim band are the same thing.
Old 07-13-2013, 06:43 PM   #23
What do you mean by hinge joint? So, the wall studs and the end gable studs have to directly above one another or can they be offset?
Old 07-13-2013, 06:48 PM   #24
GBrackins's Avatar
like a door hinge .... two walls connected by a hinge point
Gary
Old 07-13-2013, 08:17 PM   #25
Hey do you have an idea for a door that I can use? The walls are only 6 feet since its a playhouse but I need an exterior door that I can weatherproof. Obviously standard 80'' door wont work. I though of building a shed door with plywood but then not sure how I could incorporate weatherstripping and a threshold. The r.o. for the door is 54" what do you think about getting a prehung exterior and cutting the bottom to fit and the jamb. Only issue is the threshold would be cut off.
Old 07-13-2013, 08:20 PM   #26
JOATMON
ddawg16's Avatar
Rewards Points: 1,168
In my area....beside the rim board....I also have to have blocking between the joists at the rim board. This basically gives me 3" of wood to nail into.
Additionally....wouldn't the subfloor be there as well? Hence....
Studs
Bottom plate
Sub-floor
Floor joists.
ddawg16 is online now   Reply With Quote
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 05:56 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
