Wall Help! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2010, 12:43 PM   #1
Wall Help!
I am hoping someone can help me!
I live in a 2 family duplex in Massachusetts that was built in 1897. We have a stone foundation and wood frame construction. An inspector we hired showed us that our exterior wall is bowing quite a bit. However, he was not sure why. He also asked a friend of his who is an engineer, and he was also not certain. There was an addition made to the back of the building at some point in the past 100 years, which can be seen as the bowing is more obvious on the exterior wall of the addition.
I am trying to figure out if this is structural or just "an ugly look" issue, and what it may be due to. The "bowing" looks like it may stem from the addition. Any help would be great!
Thanks!
Woodframe is offline   Reply With Quote
Old 08-17-2010, 12:53 PM   #2
bowed wall in massachusetts
two things about your wall .If it is bowed from top to bottom,it is probably the way it dried,but if it is on the length of the wall, its probably that when they put the foundation. it was not square whit the rest of the house ?
frenchmexican is offline   Reply With Quote
Old 08-17-2010, 01:20 PM   #3
Thanks.
It bows along the length as opposed to up and down.
It's been like this evidently for a very long time. Just trying to figure it out. If the foundation wasn't square and therefore the walls are bowing, do you think there is any issue as far as collapse or will it just look bad.
Thanks again!
Old 08-17-2010, 01:23 PM   #4
fabrk8r
fabrk8r's Avatar
Do you know if the home was built with "balloon framing" or was it built using "platform framing"?
Does the roof ridge show any signs of sagging?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-17-2010, 01:29 PM   #5
No real sagging on the roof ridge that I can make out (Actually - I take that back. I am not 100% certain if there is. It may do so slightly - nothing too signficant if it does).
As far as the balloon framing versus platform framing, most likely balloon framing. Thoughts? Thanks again.
Old 08-17-2010, 01:42 PM   #6
fabrk8r
fabrk8r's Avatar
I'm trying to find some resources for you to check that may help you out. I'll check back later when I get some time.
For now here is a link to a thread someone else started a few years ago that sounds similar to your situation.
Roof Sagging wall bowing
The Following User Says Thank You to fabrk8r For This Useful Post:
Woodframe (08-17-2010)
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 02:50 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
