Old 01-20-2006, 07:28 PM   #1
Wall height
I know local building codes will prevail but does anybody know if I can build my cabin with 90" studs. Including three plates I will be a bit shy of the standard ceiling height. The reason for this is I am building with recycled lumber and have a large number of 90" 2x4's
Puppy is offline   Reply With Quote
Old 01-21-2006, 11:36 AM   #2
robertcdf's Avatar
Wall height
I should think you might be able to however around here they dont like 3 top plates. Because they cannot tell if there are nails in the middle plate. Sometimes they will allow you to do this but you may have to bolt the plates together every 16"-24" just depends upon your area Then again they may not allow you to use the shorter studs
robertcdf is offline   Reply With Quote
Old 01-21-2006, 03:12 PM   #3
2nd half
Wall height
I think what he's referring to is a bottom plate and two top plates. And to answer your question your're only 2 5/8" shorter than a normal 8" wall, no problem.
jmic is offline   Reply With Quote
Old 01-21-2006, 07:06 PM   #4
Contractor
Wall height
I know of no code as to ceiling heights. 8' is a building STANDARD but not a code. A lot of manufactured homes have them lower and my florida room isn't 8'.
It is all going to depend on your local code. Here, I could have 48" ceilings if I wanted them.
Teetorbilt is offline   Reply With Quote
Old 01-23-2006, 05:54 PM   #5
robertcdf's Avatar
Wall height
2 top plates is standard if you are not using 2 top plates something is wrong with you. 92 5/8" standard studs + 1 bottom plate 1 1/2" + 2 top plates 3" = 97 1/8" 90" studs + 1 bottom plate 1 1/2" + 3 top plates 4 1/2" = 96" differance of 1 1/8"
Old 01-23-2006, 06:00 PM   #6
2nd half
Wall height
The original poster says nothing about a bottom plate and (3) top plates, he only mentions (3) plates which normally would be a bottom plate and (2) top plates.
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 05:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
