Wall Framing Help Please - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-16-2008, 07:08 PM   #1
cdg
wall framing help please
I need help my husband is out of town and wants a wall with a door built in his office before he gets home. Do I use 2x 4's, how far apart should they be spaced so that I can put insulation between them and any other helpfull advice that can be given would be great
cdg is offline   Reply With Quote
Old 02-17-2008, 12:22 AM   #2
yummy mummy's Avatar
Rewards Points: 1,016
The spacing of studs should be 16 inches on center.
The insulation will fit right in if they are spaced 16 inches apart.
yummy mummy is offline   Reply With Quote
Old 02-17-2008, 12:33 AM   #3
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Wow, lucky guy!
DIY chicks RULE!!!!
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 02-17-2008, 06:15 AM   #4
Have you ever built a wall? Or installed a door?
Just wondering how detailed to get here.Seems like maybe a bet going on here........................Hope you win.
mark942 is offline   Reply With Quote
Old 02-17-2008, 09:20 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
These Links can get you moving in the right direction:
Good Luck.
http://www.doityourself.com/stry/h2frameadoor
http://www.homeadditionplus.com/fram...or-Opening.htm
- Build Well -
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Framing an angled wall TheBrownsFan Building & Construction 8 01-14-2007 10:22 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
